13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
610 Questions View all
Where is the airport connecter on the logic board?
I opend the lower case to clean the fan today,and when i turned it back on, it said no airport card, i think i may have accidently dissocnected it.
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
Check the connectors and the card connectors on the logicboard. If it's loose, reconnect it. If that doesn't work, replace the WiFi card or the WiFi card fuse. You may even have to replace both. You can see these guides on how to do the repair here.
Score 2
Comments:
I dont know what connecter it is, and it shouldn't be bad because i used it for most of today
by
They are on the airport card. maybe one came loose
by
The airport now works sometimes, i didn't open the compputer back up even, but now it isn't working... is the airport card on the keyboard side of the logic board or the under side/.
by
Now check how well it is in the slot and if the card is REAL secure it is failing
by
Where is the airport carD?
by
Show 3 more comments
Add a comment
Most Helpful Answer
The Airport card on this model sits in the base of the display, next to its antenna. It is connected to the logic board via the LVDS cable.
Score 3
Add a comment
Add your answer
Kavanagh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,109
