How to fix touch after screen replacement?
I changed the front screen on an iPod touch 5th gen and the screen works fine but it's unresponsive to touch! Anyone know how to fix this?
1/ Assuming that the touch function was working before your replaced the screen:
Disconnect the screen cable from the board. Clean the connectors with isopropyl alcohol 90%+ if you suspect they are dirty or just to be safe.
Then reseat them gently, but make sure they are properly connected. Hard-reboot and try your iPod.
If it still doesn't work, you could be using a defective replacement screen, or may have damaged it during installation.
2/ If the touch function was not working to begin with, even before you tried replacing the screen the first time, try a hard-reboot just to be on the safe side. If no change, then you could have a problem on the logic board that needs some special skills and tools to find and repair.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 401
