The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
100 Questions View all
Question Closed
Fan at 100% and slow after liquid spill - SMC seems defective
Hey,
I accidentally spilled some water (pure without gas) on my MacBook Air. After drying it out it starts with a progress bar, the fan is at 100% and the MacBook is extremely slow.
Also the battery is not charging and not showing a green or orange light on the magsafe.
Well, if I put it in sleep mode and wake it up, it works perfectly (!) for 10 seconds. Then again the kernel_task is at 350% and the fan at 100%.
I flashed the SMC on my own with rEFIt, hoping to get it work but it didn't help. But it got flashed successfully so the SMC and the communication with it shouldn't be broken, or? On the other hand the apple diagnostics are telling me that there might be a problem with the SMC...
Now if I disconnect the battery, hold down the power key for 5 sec and then connect the magsafe still holding the key it's working perfectly but with fans at 100% and still not showing a light on the magsafe.
So my questions to you are: do you have some ideas what else I could try? Is there maybe some way or some company which can repair the SMC chip? Why is it possible to flash it but a SMC reset isn't working and the Mac seems having problems communicating with it?
My last idea would be to bake the logic board. But thats really the last thing I'd like to try...
Really hope you can help me out. Thanks in advance for every answer!
Add a comment
1 Answer
There are no software fixes for hardware damage. Try cleaning the logic board before baking (others who baked boards have had components fall off). Even after cleaning rinse with 90% or better alcohol … less has to many ions in the water.
Read some of the other answers for repairing liquid damage.
Instead of finding out what components are damaged (examining) your machine you want to jump to big, quick fixes that may not work at all (if they're not the source of the problem you're wasting effort).
If this answer is acceptable please remember to return and mark it accepted.
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 327
