Repair guides, support, and troubleshooting information for MacBook Air models with 11-inch displays.
929 Questions View all
Question Closed
Dented Aluminium Case Replacement
Hi,
I have MacBook air 11.6" which is working properly, my problem is my MacBook was fall down 3, 4 times and it badly dented around the body.
I want to change out the body shell Is it possible?
Please replay, thanks
Add a comment
1 Answer
Chosen Solution
Your best bet is to locate a water damaged system which has an unblemished body. Then strip it down and swap out your working parts into it.
While this is possible it does have risks! First are you skilled enough to do this? Are the parts you can't replace still working?
This is not something I would attempt if you've never worked on MacBooks. You may end up just making a big costly mess!
As an alternative why don't you look at getting body covers. Many look dam good! We apply an adhesive version which has our graphics & logo (less likely to be stolen).
Score 2
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 857
