Drum Roller
If the dryer won't turn, and the belt is not broken, the next thing to check are the drum rollers. Every dryer has either 2 or 4 drum rollers. Over time these rollers wear out and can prevent the dryer from turning properly.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to bind. If the dryer won't turn, check these axles to be certain they are not worn out. If the rollers spin freely without wobbling, the axles are still fine. If the roller wobbles, replace both the roller and the axle that is worn out.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer won't turn during the cycle it may be that this drum bearing has worn out.
Drum Support Roller & Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer won't turn. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer won't turn check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer won't turn. Replace all of the glides as a set if they are worn out.
Drive Motor
The motor should spin freely when the belt is disconnected. If it doesn't, check to be certain there isn't anything caught in the blower wheel. If the blower wheel is clear and the dryer still won't turn, the motor may be defective. All dryer motors have sealed bearings and can't be lubricated. Replace the motor if it doesn't turn freely.
have you ever figured this issue out?
by jonman504
