iPhone 3G Glass/Digiter Replacement: Screen Now Black
Ok, so I replaced the glass and put it back together only to get a black screen. I took it back apart and I think the #3 ribbon was pulled out but I'm not certain. The whole time, the phone functions (iTunes sync, mute button toggle causes vibration).
So here's what I've done with no success:
1. Changed back to the old (cracked) screen
2. Attempted hard reset (power + home). I'm not certain the home button was working at this point.
3. Discharged battery, recharged, hard reset
4. Discharged, re-seat cables 1, 2, 3. Charge. Hard Reset
5. Discharged. Pull logic board from battery to allow full power down. Reassemble. Charge. Startup. Hard reset.
Its sitting on the wall charger now in some hope that it needs a full charge for a proper hard reset.
Any ideas?! Help would be greatly appreciated as Google's not giving me much at this point.
Oh, I've tried to swipe the unlock button several times, but I've never heard the unlock sound so I'm pretty sure both the LCD and the digitizer aren't being recognized.
Thanks in advance....
Lucas
4 Comments
I have had exactly the same problem.
You had any luck yet?
Thanks
by Chris Bowers
Exact same problem. ugh..
by Garret Bluhm
I am so glad I stumbled across your page!!!! Thank you so much!!
by nic
I had this to also my battery acted like it was dead so I tore down the phone and took a small paint brush the kind that kids use to paint paint by #s real small but, not the fake ones with the hard plastic hairs. Mine has nice soft hairs like a real paint brush anyway, I brushed out all the connected cabels each side then I took a drop of alcohol, rubbing alcohol I used the clear and, rebrushed all connectors, I made certain I got the mother board connected in good this time. Put it all back together and, walla its working with a few issues like not finding a service connection but, its better then before.. I hope this helps someone..
by tonya Hayes
