Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
after battery replacement no wifi
After replacing the battery in the iPhone 3GS (good kit and instructions), everything seems to be fine, but i can only capture a wifi signal very close to the router. So I'm guessing some kind of antena issue? Did I forget or move something in the reassembly process that might cause that? Thanks.
Score -1
Add a comment
1 Answer
Chosen Solution
Open up again and make sure number 6 connector is connected properly
Add a comment
Add your answer
ddblack will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 86
