Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Volume bar in control hub GONE!
So one day I turned on my phone and put on some music. I didn't hear anything. I looked and saw that the music was playing but there was no volume! I pressed the + button and the volume image came up but there was no bars indicating that the volume went up! I might have dropped it in water, but now I cant hear anything!! PLEASE HELP!!!!!!!!!!!!!!!!!!!!!
P.S I don't drink alcohol
Score -1
Add a comment
Chosen Solution
This is rubing alcohol not actual alcohol you drink.
Changing the charging port will fix your problem
Score 1
Add a comment
Most Helpful Answer
Hello it's a common problem it's a fault with the charging port it thinks it in a docking station..
A simple clean with some ISO alcohol and a toothbrush in the charging port can fix this if it doesn't you will new a new charging port..
And this will 100% fix the issue
Score 1
1 Comment:
Thanks for ur help bro, but i dropped my phone and its done for, anyway it was old
by
Add a comment
Add your answer
Jump St will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 67
