Repair guides and support for all types of batteries.
74 Questions View all
Risks of short-circuiting Li-ion battery?
I received a new Haier Li-ion battery (haier h11255) for my cell phone and although it seems identical to the old one, it does not work. After some tinkering I discovered that the 4 'pins' on the battery are in another order then they should be. I can easily fix this by connecting two of the pins, which I tried using a paperclip. Is there any risk doing this? If so, what are they?
Score -1
Add a comment
Chosen Solution
Definitely get rid of that battery. One of the four pins is used to measure BTemp (battery temp.). When it's temp. is beyond a specified range, the battery will stop charging to prevent overheating. Unordered pins are a bad sign.
Add a comment
Most Helpful Answer
Return the battery and get the correct one. Don't chance it!
The battery can explode or catch on fire if sorted.
Score 1
Add a comment
Add your answer
Tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 525
