Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2971 Questions View all
water damaged iPhone but only while connecting to power, still work
Hi guys
While skiing, I kept my iPhone4s in my trowser pocket. Certainly It was not good place but I did it, water droplets any how succeded to went inside phone and it was turned off. On same day whole night I put iPhone under table lamp to get it dryout. Again next day it was not turning on. Latter on, when I connected to power, all functions are working and after removal of power again switched off. Please suggest me what to do.
Thanx in advance...
Comments:
Thnx for useful reply. I did the aforesaid above and my iphone is working now. The problem I am facing now is the short life time of battery. After full charging, my iphone battery life is around 4-5 hours only. Kindly suggest any useful way to enhance the battery life time.
Thnx in advance
by
You did get a new battery?
by
Yes, I put new battery
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
ajay, the table lamp will not evaporate enough water. You will have ongoing corrosion damage. I suggest that you using the device, (remove the battery) and totally disassemble it. Then clean it with +90% isopropyl alcohol. This will displace the water and stop corrosion. It it okay to submerge a board in isopropyl alcohol. After that, air dry all the components. Do not forget to clean the connectors on the board as well as the cables. Then re-assemble with a new battery This is not optional but a must to avoid failure later on. " Check your board for any missing or damaged component. Water damage is the toughest to trouble shoot and to repair. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
ajay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 76
