Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
Hard Drive Temp Sensor Cable
how can i get a new Hard Drive Temp Sensor Cable Late 2009 4 pin one not the 8 pin
Add a comment
1 Answer
Chosen Solution
It depends on which HD you are planning on using here. Apple has three cables for the drives that were out at that time:
  • 922-9215 - Hitachi
  • 922-9216 - Seagate
  • 922-9217 - Western Digital
Some newer drives may require a different method. This when the older HD Temp Sensor cable may be needed. In this case you apply it to the casing near the spindle motor.
Score 2
9 Comments:
i looking to use the SSHD 2 TB one because it i will faster
by
Seagate's? Can you give us the details of the drive so we can make sure you get the correct cable.
by
Seagate ST2000DX001 SSHD 2TB 3.5in SATA3 64MB Cache Internal Solid State Hybrid Drive OEM
Drive Type Internal
Height 0.4"
Width 4"
Depth 5.8"
Drive Interface SATA
Drive Width 3.5"
Drive Interface Standard SATA/600
ProductId 1025158535
by
Get the Seagate cable
by
can u give me a link and is it the 4 pin one?
by
Show 4 more comments
Add a comment
Add your answer
paul will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 379
