Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
iPod won't turn on, stuck on Apple Logo Splash Screen.
Well, one day, I decided to try to sync my iPod (80 gig 5th Gen Classic) with Winamp, and, at the same time, unbeknownst to me, iTunes was doing something with it at the same time. Long story short, it won't be recognized by my laptop (Windows Vista Home Premium, SP2) and is stuck on the Apple Logo Splash Screen thing. I've tried to let it die, and then try to turn it on after a while, but that hasn't worked yet. This just happened yesterday, so the problem's still fresh. I've tried using all the wires in my possesion, and even went as far as to borrow a friend's, so I'm pretty sure it's not the wire. I've tried hard resetting it multiple times, if holding the Menu and Select button at the same time and waiting until the splash screen shows up is what hard resetting it is.. Help is GREATLY appreciated. Thanks!
Score -1
Add a comment
1 Answer
Chosen Solution
I would try to boot the iPod into disk mode and restore it.
to go into disk mode, toggle the hold switch to ensure it's switched off.
press the menu and the select button until the iPod switches off. immediatly press and hold the select and the play button until the iPod boots up and shows "disk mode". plug in the iPod and start itunes. the iPod should now be recognized and then restore the original firmware - you will lose everything whats on it - but you should have a working iPod after that.
good luck
Add a comment
Add your answer
pritom chowdhury will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 8,149
