Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Questions View all
Mid-2012 MacBook Pro won't charge with stock L-tip, works with T-tip
I have a mid 2012 MBP with an i7 and GTX 650M. It came with an 85W L-tipped magsafe AC adapter. It now no longer makes a connection in any way, the LED on the adapter doesn't light up, and the MBP doesn't respond to being plugged in at all. I tried the AC adapter on other Macs, and it works as it should. I then happened to try the 85W T-tipped magsafe off my girlfriend's older C2D Mac, and it works, but you have to move it around to make a connection. I've tried resetting the SMC, but it doesn't seem to change anything. I'm not even sure I've done it correctly as there is no onscreen confirmation or anything that would indicate a change. I've tried updating the firmware directly but it tells me I don't need it. What does this indicate to you? Do you think it is merely the port on the MBP? I opened it up and it doesn't seem hard to change. There is even an ebay listing for just this, which I am certain I could do myself, but I might as well spend a few more bucks and get the whole unit. The Magsafe daughterboard is marked 820-2565-A, and a search seems to indicate that the same board is found in many other MBs, some of which may not be the same wattage? Does that matter? Or are they the same?
Cheers,
Alex
Score 1
Add a comment
1 Answer
Chosen Solution
Sounds like the connector on the system has deformed. Do a visual inspection comparing it between your girlfriends system. Don't put any metal into the connector as you could damage things.
You'll likely need to replace the MagSafe DC-In Board, follow this IFIXIT guide: MagSafe DC-In Board Replacement and you may need to replace the AC adapter if the MagSafe contacts are damaged. You may try cleaning with the contacts with some Isopropyl alcohol first if they look dirty.
Score 1
Add a comment
Add your answer
Alex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 252
