Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Won't turn on, only vibrates twice
Hi Ifixit, i replaced the volume and headphone jack cable and earpiece, then assambled the iphone.. but now it doesn't turn on so i connect the usb charger and it only vibrates twice.
I check all connectors (screen/digitizer/camera) and it seems well connected.
Any solution?
Thanks.
Score -1
Add a comment
Is it recognized by iTunes when you plug it into your PC? It could be in some sort of recovery or DFU mode. When you try to turn it on, hold down both your power and home buttons together for 15 to 30 seconds and see if it boots. If it's stuck in some kind of recovery mode that should kick it out and let you use it normally. Other than that, if it's not your screen cable I 'm not sure what it could be.
Add a comment
Doubt it's in a recovery mode just sounds like a damaged or screen connections are plugged in correctly
1 Comment:
yes, i've been searching an apears to be the screen, so i'm going to borrow one of a friend to replace it and see whats happen.
by
Add a comment
Add your answer
Mauricio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 728
