Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Won't charge after replacing Screen
I replaced the screen with an iFixit screen and it works great. My only issue is the battery won't charge now. Is there something I may have forgotten to connect when putting it back together?
Kinda lost right now.
Score -1
Add a comment
Hello it would be hard to damage this part with only a screen replacement .. But replace the dock connecter and see does that fix it .. If not then you have damaged the motherboard somehow
1 Comment:
I also did try to replace the battery and failed when taking off the adhesive. I might have done something there? I just gave up and and put it back together. Going to try again to replace the battery and see if that works.
Thanks for the help!
by
Add a comment
This happened to me with a different version of iPhone. Long story short what happened is that I somehow broke off a very tiny jumper right next to where the battery connects to the logic board. If you have a magnifier with light, open the phone and inspect the logic board very carefully for broken/missing jumpers. You won't be able to see anything without the magnifier. If that's the case, you'll need to micro-solder to fix it.
Sorry, this is more likely the problem if a battery change doesn't fix the charging issue. Hope this helps.
Add a comment
Add your answer
joshuasneider will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 83
