How to Factory Reset / Hard Reset Tracfone LG L34C Optimus Fuel
Herman Anderson Tracfone Hard Reset
Performing Factory Reset on Tracfone LG L34C Optimus Fuel – Have any problem, glitches, issue, bugs and software problem on your Tracfone LG L34C Optimus Fuel and no matter what you do, those problems are still there? If that so, then it is time for you to perform hard reset.
Hard reset or factory reset is the term that was used to bring your device back to what it was when it left the factory. Meaning that there are no 3rd party applications or any data that you add after you bought it.
Factory Reset Tracfone LG L34C
Is this action worth to do? The answer is yes, especially when you encounter problem that you can’t solve with other action.
Performing hard reset is not that difficult. You can do this using two methods. The first one is by accessing factory reset from system setting in your device. This is the normal way to do it, but if you can’t do it for whatever reason you have in there, use the second method.
Soft Factory Reset Tracfone LG L34C
Start by go to phone Settings.
Find the “Backup & Reset” option among the available menu and tap on it.
You will find more option, and you need to find “Factory Data Reset” and then tap on it.
At the bottom, you will see the option of “Reset Phone”, tap on this option as well.
Enter your unlock sequence if you have configured one, then tap “Erase Everything” and OK to confirm.
Wait until the process is completed, where the phone will reboot back to its normal mode.
RELATED POST: Tracfone LG L34C Optimus Fuel User Manual Guide and Instructions
Hard Factory Reset Tracfone LG L34C
It’s a little bit complicated, but as long as you follow the guide, you will be all right:
Power OFF the phone.
Press and hold Power button and Volume Down button in the same time for several seconds.
Keep doing this until you see LG logo appear on the screen. When the logo is appear, release both buttons but for 1 seconds only.
Remember that release both buttons just for 1 seconds before you press and hold them once again.
When you do it right, the device will boot into Recovery Mode where you can see it on the screen and this is where you can release both buttons.
In recovery mode, you can navigate through the menu using Power Up and Down button.
Use those buttons to find and the highlight “Wipe Data / Factory Reset” option. Use Power button to make the selection.
Select the “Yes” option on the first dialog box and another dialog box will also show up to confirm your action. In the second dialog box, select “Yes” and let the factory reset process begin.
It is not that difficult and with a little practice you can do it smoothly. Now, always remember to back up your data before you perform this action. Do the backup either manually or using specific software or any other way you prefer so you can restore it back after the factory reset complete
if i do this reset to my g stylo, will i go back to lollipop or am i stuck with marshmallow? because with mine i can't switch any of my apps from internal storage to my 64gb microsd card i bought from target 3 months ago. i get the error message stating not enough space.
by Malcolm Ellison
My lg ms345 had says no command after I tried to update it and it said error so I took out the battery and that's what it says
by tjcalvin123
I had to do a remote wipe using Norton I had on m phone and It worked
by farisfly05
I hold down the power button and volume button but the LG sign comes on and goes off repeating what do I do
by Krystal
I can't seen to hard set my phone,is there any other wayci can rest it
take
by fredricware
I have the same problem I try to factory reset it and keeps giving me the lg logo then shuts of and shows it agian any help please
by Ivys
i want reset mobile phone lg g5 , i have already tried using down volume and power button and setting wizard
by zhidru
I only see FACTORY RESET MODE on my phone...
by Jestoni Santiago
Press and hold the Power and Volume down buttons on the device. When the LG logo appears, quickly release the down botton while keeping your other finger on the power button. Press the Volume down button.
After struggling with following the standard reset instructions and getting the same results as everyone else on this topic, , I tried this variation and it work for me the first time. Hope this helps someone.
by Harold Klous
Harold i tried your method all it did was put my phone in safe mode. i put a new keyboard that required a screen lock combination and when put it in it does'nt work.
by redeye_1999
I am having pretty much same problem phone will not hard rest. Just reboots and i am in same situation.
by Renee Finazzo
I tried everything I possible could. No luck No reset and no phone. Ready to smash and buy HTC
by Jimbo Eastridge
Hey Krystal are u good at LG phones
by Tanna Hostetter
Is anybody good at resting LG phones if so I need help please and thank u and I don’t know what to do
by Tanna Hostetter
How to get my assist button to show up. When I hold down a word only copy and paste show up
by jerry james
I have performed a hard reset on a LGH343 and it does not wipe any data frim phine im licked out of phone because i forgot pin what can i di
by Celia Mauro
Show 11 more comments
