The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
98 Questions View all
repair just screen or full lcd and digitizer
Hi
I have a broken screen however I can naviagate around the menu and select a few (Only on the bottom half of the cracked screen) apps
What kind of repair do I need
Please help
Ty in advance
Mike
Score -1
Add a comment
Most Helpful Answer
As long as you see your display working all u need is just to replace the digitizer
Score 1
2 Comments:
Thanks for the quick reply
The display works and as I said I can select a few aps,there is no damage to the colours at all
Is the digitizer cracked screen?
by
Is the procedure for replacement of the digitizer the same as for both digitzer and lcd?
by
Add a comment
Mike, it is possible to separate the digitizer and the LCD. But, definitely not easy, you are runnig a great risk of breaking the LCD. You could use and LCD separator machine and it would yield better results. Once separated, you will still have to adhere it together. Unless you have worked with (L)OCA before, it can be a mess and a PITA to get to fit and cure properly. If you have not done this type of repair, I suggest that you replace the whole assembly. It will be cheaper and have a greater chance of success. Hope this helps, good luck.
5 Comments:
This... if you have the correct machine/moulds and experience it's not as difficult, but with your average heat gun and pry tool you will damage something. The LCD can be purchased for £25 anyway
by
Than you for your quick answer.
I haven't tried before to disassamble Sony but only Nokia N9 and HTC Desire.
Problem is that I bought from USA only digitizer before realize the full problem of replacement in Sony Z C6603.
Maybe I could give it a try and if no success then buy the complete set from England about 50£ inclusive freight?
Too expensive in Denmark!
by
David James where to buy for £25 I only find this
http://www.ebay.com/sch/Replacement-Part...
by
That's to be dispatched from the UK, they will import the screen from China in bulk and then sell for considerably more. If you buy directly from the supplier in China it will be £25 (same quality screen in most cases, find a good seller) but will take 2 weeks. I picked an Xperia Z up for £25 yesterday with a faulty digitizer and bought a screen for the same cost on Aliexpress.
by
Thank you all of you for your help!
by
Add a comment
Add your answer
Mike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,957
