Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Questions View all
I have a cracked white screen! No mac no $ Help?
My boyfriend dropped my macbook pro on the floor after being hit by the fan spinning above his head. Hes tall so it fell hard cracked the screen and worked for about twenty minutes before it took a dump. Now when i turn it on i get a white screen a clicking sound then a file folder icon blinks off and on with a question mark in the middle of it. What can i do to fix it? I am determined. I use it for everything and time is money when theres mouths to feed. Please HELP
Score -1
Add a comment
1 Answer
Chosen Solution
Ouch! ...
Sadly, it sounds like the hard disk also went on you as well. To test things see if you can find the recovery disk that came with your system and try booting up with it. Or, if you don't have it do you have a bootable external drive. it will work as well here.
If you don't have either see if you can get your self to an Apple Store with your system so they can check it out.
Both are expensive parts.
Score 2
Add a comment
Add your answer
Julie will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 119
