The Acer Aspire One D150 is an affordable 10.5" laptop with an Intel Atom CPU. The Acer Aspire line is aimed at casual household users and covers both desktop and laptop PCs.
6 Questions View all
HDD Not Recognized on Install?
Hi !
when i try to install Windows 7 from USB, when i get to the part of installation on you must select the HDD, the list is empty, no HDD found :(
any advice ?
tks
Score -1
Add a comment
Did u format the hdd before trying to install the system? U have to create a partition and format it.
Add a comment
Have you just installed a HDD?
If so, is the hard disk plugged in, both power and data cables? Most modern hard disks use SATA cables; see this page on Wikipedia for pictures.
Add a comment
yes !
but i solved, i've used another HDD that was reconized, then after install i've cloned the HDD to the one that wasn't reconized and solved the issue :)
Add a comment
Add your answer
zecompadre will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 5
All Time: 209
