Netbooks need repair too, though they aren't very common these days. Keep yours going with our Netbook repair guides.
503 Questions View all
Screen replacement for Nextbook 8 NX785QC8G
I recently dropped my Nextbook 8 and the Digitizer broke, I need to replace it but I don't know how to take it apart since it has no screws on the outside. I also need a link to a new digitizer screen because I'm not sure as to which one it needs. Thank you for your help!
Score 14
1 Comment
Where can I buy a screen for it
by
Add a comment
Most Helpful Answer
You could buy a new digitizer from ebay
New-Digitizer-Touch-Screen-Panel-For-Nex...
Score 3
Add a comment
if you look at the edge of the tablet there's a seam. you want to get a really tiny screwdriver and slow try to open it. when you hear a pop that means the clips on the inside have released and you want to do that all the way around the side of the tablet.
By,Jahn Peabody
Score 2
1 Comment:
After I put it back together the touch screen is not working and it w
as before. No I have not replaced the screen as of yet.
by
Add a comment
I think I'm having the same problem. Dropped my nextbook and it is cracked across the screen. It's crack left to right at the middle of the tablet. I can't use the top portion because the touch screen isn't working on the top. Bellow the crack it's fine. How would I go about replacing it when I get the screen replacement?
Score 1
Add a comment
Yes how much it cost to replace it
Add a comment
How to fix the part were the charger goes into the nextbook
Add a comment
Add your answer
Alexander will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 5,747
