Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
Compatible with volt from France
iMac Intel 27" (EMC No. 2309, 2374, 2390 or 2429) Power Supply / it is compatible with imac from France
Score -1
Add a comment
1 Answer
Chosen Solution
Yes, Apple uses a dual voltage power supply 120/220v. I would strongly recommend using a UPS if you have questionable power (lights flicker or get dim). Even here in the states we have bad power to the point we have UPS's at the field offices (trailers at work sites) and even in the offices the engineering stations do as well as the risk of loosing a days work is too risky.
Score 2
Add a comment
Add your answer
clem will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 62
