A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1696 Questions View all
Question Closed
Blue Light of Death! any Solution?
Hello guys,
I just want to know if anyone could fix the PS4 blue light prblm without sendin it back to Sony ?
Greetings
3 Comments
I don't know if you ever got your console fixed or not, but I can fix most blue light of death PS4's. This problem is not an easy fix and needs to be sent to someone. There are some people on ifixit as well as other websites that can do it, including myself.
by
Thank you for your replay, Actually i fixed my PS4, i just made some force on the top side "not the glossy one" and now it works perfectly.
Greetings
by
That's awesome that you were able to fix it! I can't believe that it was an easy fix! Hopefully it lasts a long time!
by
Add a comment
1 Answer
Most Helpful Answer
The Answer for blue light of death is Ps4 starts acting up weirdly like doesn't take ps4 disc in and ejects it automatically I don't know if iam correct if that is the problem you are experiencing. and if so try solving the problems following these methods:
1) reset the system to defult settings and if that doesn't work
2) Try doing Hard shut down meaning shut the power switsch off and unplug the plug directly from the console wait 30 minutes and plug back everything in again
3) if that doesn't work then give it a slight tap on top of the console again unplug the plug directly from the console, leave it for a day unused, and plug back everything the next day and try that hopefully that should solve the problem for you.
Just before you do these procedures back up your trophies and important data into external hard drive and make sure that your system software is also up to date and if not up to date then update the system.
I have had this issue happened and It had happened because of destiny game that every time you play the game it needs new and new updates causing system issues I have also heard that game has had some glitches in it and have not been well designed so, try these 3 steps and see if it works and if it works then email me at mihirpatelmickey@hotmail.com
Update
If these don't solve the problem then you will need to reapply thermal paste on heat sink adhesives because some ps4 have heating issues not all of them.
In order to do that you will have to disassemble the whole unit
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 670
