The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3870 Questions View all
Screen Replacement problem - Phone will boot until it's snapped in
I dropped my iPhone 5s and the glass and lcd shattered. Luckily I had another 5s that had a bad charging port so I decided to swap the good screen and glass from it to the broken one. The swap went fine, with tutorials I found online. I kept all the screws for the "cable plate" where they should go and I know I got all the ribbon cables plugged in snug. Before I put it back to together, I powered it on and viola, it works great. The problem is when I go to snap the screen assembly back into the shell/bottom phone assembly, the phone will no longer turn on after it's snapped back in. I've troubleshot it down to where I get the two peices snapped in all except the right side (looking at the front) it stays powered on but then when that right side snaps in, the phone turns off, so it's something on that right side that's causing it to short or is pressing against something maybe? Both phones are orignal Apple hardware, all OEM. Any ideas from you guru iPhone repairs guys/gals?
Thanks!
Patrick
Score 1
Add a comment
iPhone Battery Fix Kits
Only $29.99
Buy Now
Only $29.99
Buy Now
Most Helpful Answer
ive had this problem before, try using koptar tape inside to stop the metal clips touching the housings, i had to use loads of it
Score 1
Add a comment
Thanks Krayzee, that's what it ended up being, the metal clips were touching something and shorting it out. Once I straightened all of them out and made sure everything was flat and straight, it would stayed powered on when snapping it back on. Success!
Patrick
Score 1
Add a comment
Add your answer
Patrick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 157
