Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Questions View all
Finder can't find the original drive.
I installed a second drive to my Mac Mini using iFixit's kit. Everything went fine except that now Finder doesn't see the original drive, even though it appears in the Disk Utility under its original name (Macintosh HD.)
I downloaded Yosemite and installed it on the new drive. (I opted for the 1TB Seagate with the SSD buffer.) The new drive seems to be working fine.
Score -1
1 Comment:
Please supply the last three digits of your serial number or give us the exact CPU spec of your model.
by
Add a comment
First check your firmware level. Follow this Apple TN: EFI and SMC firmware updates for Intel-based Macs. Make sure you have the latest.
Sounds like you might have a bad SATA cable. Who's cable did you use and the PN#
Also did you swap the drives around by chance?
Add a comment
That's because Finder doesn't normally show your main drive, even though that one isn't anymore, it was at one time. I don't know how to change it without wiping the drive with Disk Utility though.
Add a comment
Add your answer
davidsmorgan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 115
