The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
What does the f27 code mean
I have had nothing but problems with my washer for years. I have been getting f22, suds, f21 errors for ever. Today i drained it, took everything off and cleaned it that I could possibly find and I am now getting an F27 Error. I am about to use the dang thing for target practice!
Any suggestions & help is much appreciated!
Score 1
2 Comments
What is a F:27 on the Kenmore elite DRYER
by
What does IE mean on a kenmore elite washing machine?
by
Add a comment
1 Answer
Chosen Solution
Tara Barnes, target practice sounds like the way to go. My advice for that would be a Mossberg 500. Now for the error F27, that is a water level error. Try this before you take the washer out back:-) Both of the codes you mentioned can be indicators of a water level problem. Remove the supply hoses from the faucet and the fill valve. There should be small filter screens that you can remove and clean/replace. Run the water from the faucets for a few minutes. Remember to put some sort of bucket under the faucet. This might clear any debris. After that remove the lower panel, and remove the filter from the drain pump and check and clear any debris from the filter and the pump. 1. Take off the lower front panel.Remove the bottom front access panel just remove the 3 Torx screws on front bottom of machine. Slightly lift the panel and pull the bottom towards you
2. Turn the pump filter cover counter-clockwise by hand and remove. Place a bucket or pan underneath it since you will get the water spilling out of there. Removing the filter should remove all water from your washer. You also want to remove the air hose from the water level switch, and blow into the hose,as hard as possible, to clear any debris. If none of this works, you may have to repalce the water level switch. Oh yes, do not forget to check all wires and connectors to make sure they are all still properly seated. Remember that water and electricity do not mix well. Unplug your machine anytime you work on it. Hope this helps, good luck.
Score 4
1 Comment:
Great explanation. well detailed. . Thank you
by
Add a comment
Add your answer
Tara Barnes will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 23
All Time: 11,766
