The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1550 Questions View all
Tough screen not working, possible motherboard issue
I have replaced the lcd/screen on my iPhone 5c as the touch screen wasn't working. However the Screen still doesn't respond. I tried a second screen but still no luck. I am now wondering if the fault could lie with the motherboard and that the motherboard has failed?
I'm hoping this is not the case but any ideas would be greatly received.
Score 1
Add a comment
MacBook Battery Fix Kits
Starting at $69.99
Buy Now
Starting at $69.99
Buy Now
Most Helpful Answer
Hello it's possible that one of the pins on the lcd or touch cable is bent or missing!
Score 2
Comments:
Not that I can see, is it possible to to replace this cable incase this is the problem?
by
Add a comment
No you can't replace the cable you will need another screen
Comments:
I've tried 2 screens already which is what makes me think it isn't the screen
by
Add a comment
Take a magnifying glass and bright light to thoroughly examine your system board, especially near the touch screen connector to see if there's any bare solder points where it looks like something used to be there.
Did you happen to use tweezers to pop the connectors loose during the screen replacement?
Comments:
Thankyou I will try that. No I used a metal pry tool to PPP the connectiond off.
by
Add a comment
Hi,did you fix this issue
Yet?
I have a iPhone 5c but the touch screen is not working on the bottom o the screen like when I'm typing the letters
U,H and B does not work,I had tried 2 or 3 different screen
And it's the same,so I'm thinking there something wrong with the motherboard but I don't know how to fix it,
If anybody knows how can you please help me out?
Add a comment
dont know try switching it off and on again
Add a comment
I have 3 iPhone 5c phones they all do the same with perfect working screens if I put it to sleep then try again it works for a minute then happens again randomly
Comments:
Can't be sure without thorough inspection under microscope. However, your issue is most likely related to IC responsible for your touch. The issue is very common in the newer iPhones, but can still affect older ones depending on impact or water damage. In some cases the actual connector may have issues as well, this should be easily able to be seen with a lit magnifying glass if you don't have a microscope available. Both issues are repairable but may not be worth it for those devices.
by
Add a comment
Add a comment
Add your answer
Laura R will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 39
All Time: 1,254
