Razor's A2 kick scooter was released in 2000, replacing the classic A model. Improvements from the original Razor A include a spring suspension and an added wheelie bar.
3 Questions View all
Question Closed
Why do my wheels wobble when going down a hill?
Whenever I go down a large hill, my wheels starts to wobble and shake uncontrollably about half way down the hill. This problem only happens going downhill and makes the scooter very difficult to control.
Add a comment
1 Answer
Most Helpful Answer
When you say wobble, do you mean from side to side, or is it more of a vibration?
If it wobbles:
Take a look at the wheel and see if it can move bend from side to side when you use your hands. It should be nice and stiff with no play.
If it bends a bit and you have the tools, tighten it up. If it is tight but still wobbles, take the wheel out and check the clearance between the bearing and the wheel, it should be a nice tight fit. If it isn't you might need a replacement wheel.
If it vibrates:
It's most likely a flat spot on the wheel. The alternative is the wheel is out of round, if the wheel is new it might have been made like that (poor QC).
Score 1
Add a comment
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 112
