Why does my printer keep jamming paper?
Almost every time I try to print my paper gets jammed in the printer. I took paper out to make sure I wasn't filling it too much but it is still jamming. What else could be causing this to happen?
Score
0
If the paper tray is not overloaded and the printer keeps jamming paper then check to make sure that the paper you are using isn't curled or wrinkled. If the paper is curled or wrinkled try replacing it with paper that isn't. If this doesn't fix the problem then the printer may have a faulty paper eject frame assembly. To fix this you will need to replace the paper eject frame assembly.
by Jeffrey Barnett
