Why is my printer not turning on?
My printer is plugged in and I made sure the wall outlet I am using is good, but it still will not turn on? What else could cause this to happen?
Score
0
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 56
If your printer is plugged in to a good wall outlet and it still isn't turning on then check to make sure the power supply is good. If you don't have an extra power supply you can purchase one online or through the manufacturer. If a new power supply doesn't fix the problem then the motherboard may be bad. If the motherboard is bad you will need to replace it.
by Jeffrey Barnett
