What is this LCD model compatible with?
I recently acquired a SAMSUNG LTN170WU-L01 LCD screen I am hoping to use to repair my iMac 17 inch. Question is what iMac models may this be compatible with?
Bernie, the very first thing I know about this panel is that it would fit a Dell XPS M170. This panel is also compatible with the Unimac V4 adapter, which in turn would mean that it is not a direct replacement, but would require mods to work The better question for you to ask would be which LCD will fit your iMac. For that you would have to provide more information about your iMac. i.e. serial number to properly identify. Also, a number of LCD panel would greatly help as well.
based on your A1173 it looks like you have these specs:"1.83 GHz Core Duo (T2400)
Intro Date: January 10, 2006 Disc Date: September 6, 2006
Order No: MA199LL Model No: A1173 (EMC 2104)
Subfamily: Early 2006 Model ID: iMac4,1
Std RAM: 512 MB Std VRAM: 128 MB
Std Storage: 160.0 GB (7200 RPM) Std Optical: 8X DL "SuperDrive"" do they look right? If they do, your LCD panel has Apple part number 661-4020 and any of the 2006 will fit. iMac 17" 1.83GHz Core 2 Duo (A1195) - Mid 2006,
iMac 17" 1.83GHz Core Duo (A1173) - Early 2006,
iMac 17" 2.0GHz Core 2 Duo (A1208) - Mid 2006,
iMac 17" 2.16GHz Core 2 Duo (A1208) - Mid 2006,
The LCD panel used for that model is made Phillips and is either a LM171W02 or a LM171W02-TLB1
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 162
3 Comments
I looked under the stand, it is a Model A1173. I bought it without the LCD so I don't know the original LCD model. Seller said the old LCD was defective. He also gave me the inverter and brackets already disconnected from the unit. The video cable pins fit the socket at the back of the new replacement LCD assembly, but I'm afraid to power it on as the thing might burn up if it turns out the are not compatible with each other.
by Bernie
If the connector fits, you can give it a try. If it does not work :-) it will not ruin your LCD, it just will not work:-)
by oldturkey03
Well,I connected the LVDS cable to the new LCD, and the thing won't power up. I get a twitch of the main fan, then nada. Removed the LCD,and it powers up again.
by Bernie
