Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
412 Questions View all
My right trigger button isn't working
It still registers but it doesn't have the same sort of springy feeling. Its worth noting I think started after a fall on the trigger. I'm guessing some piece of trigger assembly either broke or got out of alignment. Unfortunately I can only seem to find on trigger repair guides for the 3DS and those seem to be about replacing a flex cable not a mechanical issue (presumably they wore out the actual electrical switch component).
Score 1
Add a comment
1 Answer
Chosen Solution
Usually after a fall the plastic around the button gets bent into the button a little bit or sometimes the button part that is inside the console rubs on the plastic.
What I do is inspect it very carefully around where the button is and find where it is sticking. They I either try to bend it back or I remove a small amount of plastic with a hobby knife or razor blade until it moves freely again.
This fixes the vast majority of these types of problems.
I hope this helps.
Score 2
Add a comment
Add your answer
Nathan Saslavsky will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 1,745
