2.26 or 2.4 GHz / White plastic unibody enclosure
Keyboard and trackpad are not functioning
For some reason my macbook keyboard and trackpad are completely non-responsive. I know for a fact that the keyboard and trackpad are not the problem. Please don't fixate on replacing the keyboard and trackpad. I've tried replacing them multiple times with the same results.
Here are some other things I have tried:
1) External keyboard and mouse work perfectly fine. I can log into OS X and everything functions normally with an external keyboard and mouse.
2) I performed an SMC reset using the built in keyboard. As I said, I know the keyboard is good.
3) I can not reset the PRAM using the built in keyboard. I can reset the PRAM with the external keyboard.
The keyboard works before the chime (SMC reset) and does not work after the chime (can not reset PRAM). It seems like the logic board is turning off the keyboard when it chimes. Not sure what could cause this. Does anyone have any ideas?
4 Comments
Forgot to mention this... I also tried completely reinstalling OS X and still had the same problem. The problem existed in the OS X install DVD environment as well.
by
Also I forgot to mention, when I go into the settings and I click on the trackpad settings it tells me no trackpad found.
by
Tried booting into a Linux Mint live dvd and I am having the same issue.
by
I've tried top cases / keyboards that came from both 2009 and 2010 models. (This style of macbook was only made in 2009 and 2010).
by
Add a comment
1 Answer
Chosen Solution
Both the internal keyboard & trackpad are connected into the same controller chip the external USB ports do. In fact they are USB devices!
So we need to look at this from a software side first.
OK, Can you run AHT on your system using the wired keyboard & mouse? Follow this Apple TN: Using Apple Hardware Test. See if it tells us any errors. The next thing I would try is starting up the system in safe mode. Follw this Apple TN: OS X - What is Safe Boot, Safe Mode?.
Let us know what you discover.
Score 3
18 Comments:
I just ran AHT and it said "No trouble found". I'm going to try an extended test and see if that returns anything different.
by
The extended test is also reporting "No trouble found.".
by
Safe mode didn't seem to solve anything either.
by
OK, Lets try a different tact here. What you'll need is to create a bootable external drive USB thumb drive or a HD (FireWire or USB). Then boot the system off your external drive. Did that make a difference?
by
I had the same problem in a Mavericks USB install environment. Also in a Snow Leopard install DVD too. I tried two different hard drives.
by
Show 13 more comments
Add a comment
Add your answer
Chuck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 10,213
