The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Questions View all
Dropped my Ipad and now my touchscreen isn't working right
I recently dropped my iPad 2, and at first it was fine. Then, I noticed the touchscreen kept freaking out as if I were scrolling it left to right continuously. Eventually, it started clicking on things by itself and now I am unable to even click from the middle of the iPad all the way to the left. The panel is cracked pretty bad at the top of the device, could that be why my touchscreen is malfunctioning? Or is it something else?
Score 3
Add a comment
Most Helpful Answer
Sounds like you need a new digitiser. That sould solve your problem. Plenty of tutorials for it if you want to tackel it yourself, just take your time. :)
Score 4
1 Comment:
Thank you for your help! I looked it up and it sounds like that's the problem to me too.
by
Add a comment
Chances are there is also a dent in the case of the iPad. The odd behavior you are describing is ghost touches on the screen. Unfortunately its nothing cool like a poltergeist has possessed your tablet and you will now be able to move objects with it. It just means that something is pressing up on the screen, causing the digitizer to misbehave.
Luckily its a very simple repair. I highly recommend taking it to a reputable local repair shop to have the repair done. It will take them no time and your iPad will be as good as new.
Score 1
1 Comment:
well ghost touches are impossible as the ipad is supported with heat as touches well y know what i mean
by
Add a comment
You know this is illegal to carry a cracked ipad, because apple doesnt want to look bad.
1 Comment:
how does it make apple look bad? its the buyers fault
by
Add a comment
Add your answer
Kelsey will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,983
