1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Questions View all
Which display is compatible w/Intel 17"?
Hello,
Apologies - I have searched through this forum, and am still coming up blank. Which is embarrassing, as this should be a simple problem.
I have an iMac 17" (iMac "Core 2 Duo" 1.83 17-Inch (IG) - A1195), and am attempting to find a compatible replacement LCD part. But there seems to be conflicting information out there on which screens are compatible (some posts say the G5 screen is compatible, others, not so much).
Does anyone have any insight on this matter?
Is there a specific part number for the display?
Any information you could assist on would be most appreciated, and thank you again!
Add a comment
Chosen Solution
Ian, you did not give us all the details about your computer. It will help if you give us at least the last four digits of your computers serial number. right now it appears as if you have a late 2006 iMac. For that the display is Apple part number 661-4020 and the panel is either a LM171W02 or a LM171W02-TLB1 and it will fit the following:
iMac 17" 1.83GHz Core 2 Duo (A1195) - Mid 2006
iMac 17" 1.83GHz Core Duo (A1173) - Early 2006
iMac 17" 2.0GHz Core 2 Duo (A1208) - Mid 2006
iMac 17" 2.16GHz Core 2 Duo (A1208) - Mid 2006
A G5 is not compatible. Just for completion sake, that is part number 661-3598 which is only compatible with
iMac G5 17" 1.6GHz G5 (A1058) - Mid 2004
iMac G5 17" 1.8GHz G5 (A1058) - Mid 2004
iMac G5 17" 1.8GHz G5 - Mid 2005
iMac G5 17" 1.9GHz G5 (A1144) - Late 2005
iMac G5 17" 2.0GHz G5 - Mid 2005
Score 1
Add a comment
Hey OldTurkey hows it going?
could you tell me for sure which screen replacement is compatable with the
17" imac? A1208
and how do I know its G5 or not.
I just bought it as a replacement until i can afford better.
Thank you much
JonnyBear
Add a comment
Add your answer
Ian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,850
