Repair guides for the MacBook Air, Apple's current line of consumer laptops.
4817 Questions View all
blue screen,wont boot up,beeping sound,
Blue screen, wont boot up
Score 1
1 Comment:
Please describe the diagnostic beeps or beep.
by
Add a comment
Hey Henry,
Seems like you might have a hardware problem. RAM in particular, the MB Air's RAM is soldered on though so you will likely have to replace the motherboard or get a new Air. Of course it could also be other hardware problems. Is the beep constant? How many seconds apart and is it in a pattern (3 beeps every 3-5 seconds? You might want to take it to a Genius bar and see what they say about it. A client experienced this problem before but it was resolved with a reboot by holding down the power button to shutdown and then power button again to power on.
Best of Luck!
Add a comment
i have tryed every reboot there is
the beeps are in 3 , 3-5 sec apart
someone also said it might be sound card or hardware problem??
1 Comment:
3 Beeps = No Good Banks. This means 1 of two things or a combination of both. Your RAM is bad or the logic board is bad. Either way, with a MB Air you would have to replace the logic board as the RAM is soldered on.
I'll see if I can find some other solution for this issue.
by
Add a comment
Add your answer
HENRY PHILLIPS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 266
