2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Question Closed
GPU 0 DIE Noise Test 8 - Sensor noise test failure
Every beetwen 5 to 20 loop test I got this error
Temp Sensor - GPU 0 Die Temp test 8 - Sensor Noise Test
-Checks that Sensor Noise is within spec.
ERROR - Sensor reading below low point
- TEST FAILED -
or
after I changed the right sensor, under the right fan
ERROR - Sensor reading above alarm point
- TEST FAILED -
whats that. everybody knows? I have to change my GPU, it/s about another sensor. what is the tehnical problem?
serial: W8805446X91
1 Comment
It will help if you identify your computer a bit better. What is your computers serial number? this will allow us to determine what hardware you have.
by
Add a comment
1 Answer
Most Helpful Answer
Your GPU chip is failing. At this point its time for a new system.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 287
