Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Won't turn on with battery but will with adapter battery shows 100%
I replaced a broken screen. Powered up and everything was fine until I noticed the microphone screen was missing. Disassembled and installed screen and after that it would not turn on.Tried to pwr up with the adapter. When it is plugged in it works but it won't work when unplugged.
Score 1
2 Comments
I have this same exact problem. Also it says it's always searching for a signal and it can't connect to wifi...would getting another battery fix that as well??
by
Edit - just to add, I was replacing the battery and this happened. Thanks!
by
Add a comment
1 Answer
Most Helpful Answer
You have damaged the battery it needs replaced
Score 1
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 84
