Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Question Closed
Call problems, changed antenna, nothing change
Hello,
iphone 4S, 16 gb , black.
GSM signal (fine)
call quality bad (both with speaker and earpiece)
sudden interruptions
same sim card/ different phone works fine.
the proximity sensor closes lcd but not digitizer so when you talk it can mute it.
I replaced antenna
then replaced proximity sensor
nothing changed.
This problem started right after I crashed my lcd.
lcd normally works fine, but what is going on?
1 Comment:
still no answer :/
by
Add a comment
I have a feeling that it's an issue relates with the ribbon cable connecting the sensor and speaker phone. I would replace it if I were you it cost only 5$ from ebay
Add a comment
I will replace it ASAP
2 Comments:
replaced with a normal sensor. still got problem.
by
not solved. what else to change?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 47
