Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
Why can't I turn the iPhone 5 on?
It was the first time to open my phone. I was going to replace my battery, but when i tried to separate front case, I could not arrange the force and I could not control it. I think the cables between front case and back case got damaged a little bit. Later I replaced the battery and I closed it. But the screen is not working. I plugged the phone to charger it overheats and makes kind of warning sounds in every 2 or 3 second. I checked from itunes it is getting charged but not any sign of light in the screen.
Add a comment
1 Answer
Most Helpful Answer
I think the cables might be damaged a little was the correct guess!
The bonging noise indicates the screen is damaged you will need to replace
Score 1
1 Comment:
Thank you. I opened it further more and came to the same conclusion. Because the cables are damaged too.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 76
