Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
710 Questions View all
Won't start up. Only hear fan for a sec.
I have a 27 inch iMac EMC 2429 that began to freeze and I would get an error message on the screen that I need to restart my computer. So I would hold power button until it shut off and then I would restart my computer. It would work fine for a while then it would need a restart again. This happened over a period of two or three days. Then on the last restart my iMac would power on and I could hear the fan start for about a second and then shut off. As long as I leave it plugged in the iMac continues to try to restart over and over again but the only thing that would happen is the fan kicks on for one second and then shut off with no video or chime. I opened it up and get only LED light 1 turns on then the second light turns on with the fan but turns off when the fan shuts off. Lights 3 and 4 never come on. Is it the power supply or am I missing something? Is there anything else it could be? I need my Mac back! Thanks in advance for any help.
Score 1
1 Comment
I have the same problem. I even replaced the power supply, but it didn't help.
by
Add a comment
Most Helpful Answer
The #1 LED indicates trickle power and you'll get it even with a bad power supply. There are a couple of recalls on the machine so knowing your serial number would help.
See what happens if you try starting with the "R" key held down.
Score 1
1 Comment:
Same result.
by
Add a comment
If it was the power supply, you wouldn't get any power at all. From what you're describing it sounds to me like a bad logic board. There was likely a flaky component that was causing your initial Kernel Panics that continued to degrade as time went on.
Add a comment
Add your answer
Angela will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 329
