Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Panel is higher on the left than the right.
Does anyone have this problem where you will feel that the left side of the panel is higher than on the right side? Because, I'm not sure is it because I drop it once, and something cracked on the inside, which push the left side of the panel out? How can I check it if something is broken in it? I need to disassemble the panel?
Score -1
Add a comment
Chosen Solution
Is the panel on the top or on the bottom side higher ??
since there are screws on the bottom side, i guess the problem is on the top side
i would use the front panel guide to open the iPhone and reseat the front panel assembly.
Add a comment
The weirdest thing is....
The higher side is top and bottom of the left, and not just top.
So, I'm confused since there is screws on the bottom, and the top has "clinch"? How can it just on one side and not the other?
Can I send this problem to the mobile store where I purchase from?
1 Comment:
I think that the store where you purchased it won't fix that, many stores are only sellers and no service points. i would use a suction cup, as mentioned in the guide and reseat the assembly on my own. you only have to lift the panel a little bit and reseat it
by
Add a comment
Add your answer
ChengNan Yang will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 525
