The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
galaxy s2 shows battery with yellow triangle
galaxy s2 shows battery with yellow triangle.
I have it charging right now. I changed the battery once but a few days later it shows the same thing. Can the replacement battery be bad as well or it a different issue?
1 Comment:
Also happens in the beginning when the battery wasnt charged for a long time but in this case the symbole disappeares after a few minutes.
by
Add a comment
1 Answer
Try a new battery if you still have the problem it's the charging port on the phone an you will need a new1 soldered in
1 Comment:
can it be a software issue where i have to use odin?
by
Add a comment
Add your answer
Subba will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,835
