Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
iPhone 5 Won't Power On or Charge
My iPhone 5 won't power on or recharge after trying everything. I even tried disconnecting the battery and plugging it in to the computer, but still nothing shows up. Is this a dock connector issue, or perhaps a logic board issue? Phone is out of warranty so I can't take back to Apple.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Wes Kroesbergen, couple of things you do want to try. First repalce the battery, if that does not work, replace the dock connector. If those are okay, you can assume you are having logic board issues (unless something else happened to the phone) If so, you will have to have the right tools and skills for further trouble shooting. I would start with the relative easy stuff. Use these guides to work on your phone. Hope this helps, good luck.
Score 1
1 Comment:
Sorry, forgot to mention that the battery was already replaced. I've picked up an iPhone with a broken screen, so I'll replace both logic board and connector at the same time. Thanks!
by
Add a comment
Add your answer
Wes Kroesbergen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 379
