How do I fix intermittent colored vertical lines on replaced display?
After replacing the display I experience occasional vertical colored lines that fill the entire display then go away. Actually replaced the screen twice. Crimped the digitizer cable the first time. This time was very careful. Also pre-bent the cables at the perforations arround the shaft of a screwdriver to insure a radius bend. I am sure all the correct screws are in the correct locations. Was also cardfull to not over torque anything but the vibrator. When viewed on edge the screen doesn't seem to be seated perfectly. It is close but I can make out variations in gap along the edge.
