The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
149 Questions View all
Question Closed
Dropped my htc one in water;it works but with touch issues.
My htc one dropped in water and i got it out immediately and opened it up to dry overnight.unfortunately,i didn't remember the rice trick.i turned it on the following day and it was varing in issues with my turning on and off.left it open a little longer and then it started working well except that the bottom touch pads were misbehaving and whenever i plugged it into my laptop or to power,the entire touch sense looses coordination.also,whenever my phone locks and i try to unlock it,its as if the screen looses all touch sense until i remove and place the battery,starting up the phone again.this is why i have had to put the backlight time out to 30 mins which runs the battery down.its over 2 weeks now,i hope i can find a solution for this as i cannot afford to buy another phone right now.thank you.
Add a comment
1 Answer
Turn it off and clean it with anti corossion spray!!!
In this kind of cases u moesent turn it on until the whole water damage is cleaned!!
One of the worst thing is to let it dry 24-48 hours cuz the corrosion starting to "eat" essential components!!!!
If u dont have technical knoledge go imidiatly to a lab!!!
Good luck
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 178
