A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
236 Questions View all
New LCD has lines running across, up and down?
Bought a new lg g2 lcd digitizer assembly with frame for a t mobile g2 and a sprint g2. I have fixed many of these and now BOTH of the phones have lines and discoloration running across the display. Doesn't look like damage, but i have checked all connections, cleaned contacts, and reset the phones. What is going on?!
Add a comment
1 Answer
Most Helpful Answer
It sounds like there is either a small mistake in your repair process, do you take the logic board off of the frame? It is more time consuming but it does eliminate the possiblity of damage the LCD connection. Or do you buy a scree with the frame already on it? However if it is not an errror in your process I would simply return the parts and try sourcing some from a different supllier.
Hope this helps!
Score 1
Comments:
thanks,yes i did buy it with frame. already tried taking apart and back together again :(
by
Add a comment
Add your answer
Austin Harris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 100
