Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
My iPhone 4 won't turn on or charge!
I have acquired an iPhone 4 and won't turn on or even charge. I have carried out various iPhone repairs in the past and was just looking for some advice on what the problem could be!
Any help would be greatly appreciated!
Score 10
5 Comments
Is the iPhone 4 water damaged? Do you know any history of it?
by
i have charged my iphone in night but stillit is not turning on
by
My iPhone4 won't charge or not comin on I need help???????
by
My iPhone 4 won't turn on I phoned my mum to say I was going out and then after I ended it about 10 minutes after that it had gone off wouldn't turn on at all I have tried charging it but still no what shall I do ???
by
when I plug my iphone4s it will not charge
by
Add a comment
Chosen Solution
Clean iPhone charging port very well with toothbrush and isopropyl alcohol. Connect to Wall Charger and Reset hold both home and power buttons for about 20 seconds until the iPhone begins to respond. If still problem, replace battery. If still problem, replace charging port assembly with flex cable.
Score 8
11 Comments:
Hi, I have replaced the battery and still the phone won't turn on unless plugged in. You suggested to replace the dock connector, why is this please?
Will
by
is the port the inside where you put the charger if it is how am i supposed yo clean that
by
My phone won't turn on or charge I tried everything help
by
thanks every much my iPhone worked when i pressed the reset hold button and power button for about 20 seconds and it now says its charging
you are my lifesavers
by
my iphone is not chraging nor turning on
do something please :-(
by
Show 6 more comments
Add a comment
Make sure your phone us turned off, and using an alcohol swab or q-tip and isopropyl alcohol gently clean inside the charging port. Typically debris will come out either black or a dark color on the q-tip, and you will know if it needed cleaned. If it is not dirty, then it is the battery or the charging port that will need to be replaced.
Score 6
5 Comments:
thank you very much
by
i cleaned it and its still not charging
by
If you cleaned it and it is still not working you may need to replace the Charging port.
by
I finally got my phone to turn on! It says that I can only get into my phone with a password, but I never had a password on my phone! What do I do?
by
if you go on to itunes and log on you can sort ur fone out from ther i done mine as i forgot my passcode but soon as i loggen on to itunes from my computer i was able to reset my iphone and start using it happy days
by
Add a comment
take out the battery and put it back in.. if that doesnt do anything try seeing if there are any screws that are loose in the back of the phone.
Score 1
Add a comment
My iphone 4 wont switch on wether it is pluged into a wall socket and after i have held both the power button and menu button . Any other ideas before changing battery and charging dock?
Add a comment
my iphone was working in the moring and now it not on and help me plss!!!!:(
Add a comment
hi Will,hold the power and menu buttons for at least 20 seconds you should then see the rabbit
cheers graham.
Add a comment
Add your answer
Will Waplington will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 21
All Time: 64,301
