Repair Guides for Sony Laptops
414 Questions View all
Laptop White Screen Problem (Death of Demons)
SONY VAIO PCG-712211W
when i turn on my laptop white screen nothing else
from bios till window load white screen only..........
i tried on my external monitor works fine no mistake...
i scan my full system no virus at all...........................
i tried disconnecting and reconnecting the display cable of my lcd screen several time but nothing works white screen only............
but one thing i did't get it........................
my lcd back panel circuit board gets overheat when the display cable is connected well i disconnect it heat goes as cool.............................
the problem is in display cable or the lcd display???
i want your opinion
u ans it i FIXIT
Score 1
1 Comment
i had to replace the display with new one because no around our local use to repair display they told to get new one instead of repair so brought from ebay at 52.39 USD
by
Add a comment
Chosen Solution
Add a comment
Most Helpful Answer
Ajit, the white light is an indication that your backlight gets power. Since it works with an external monitor, and "lcd back panel circuit board gets overheat", is a pretty good indication that your LCD driver board is shorted out. Replacing the LCD panel should fix this problem. Hoe this helps, good luck.
Score 2
Add a comment
Score 1
Add a comment
Add your answer
Ajit will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 11,209
