Repair and disassembly guides for Apple Time Capsule wireless network devices.
How can I retrieve the data from my 1st gerneration Time Capsule?
I've got a 1st generation Time capsule and the power supply is fried. I removed the 500gb Seagate drive with no problem and installed it in a USB enclosure.
Neither OSX nor Windows see the drive as anything usable. Both ask me to format the drive before I can use it.
I'm not too concerned about the Time Machine backups that are on it but I was using is as a network drive as well and would like to try to recover those files.
Add a comment
1 Answer
Chosen Solution
You need 3rd Party Mac Data Recovery Data software. Ones that I have found useful are Data Rescue 3, and DiskWarrior.
DiskWarrior can often resurrect mugged Master Directory Data. DiskWarrior is not a disk repair program in the conventional sense. It does not attempt to solve all of the possible problems that can occur with a disk. It specializes in eliminating directory errors -- the most common problems Mac OS users have with their disks.
Data Rescue 3 is the only utility that focuses on data recovery as opposed to hard drive repair.
However if there are physical problems with the drive software will not cure a hardware problem.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Add your answer
Shayne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 183
