Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Screen Cracked can not see anything every thing is black .
Hello i dropped my iphone on the road while riding my bike and a steep hill came i got excited and decided to go fast like legit fast . i Didn't realize my had fallen out my pocket until came home. i retraced my steps found my iphone turns out a car ran over it. i tried turning it on but it didnt work light was coming from the screen but couldn't see anything. i than went to the store they asked me120$ to fix it. that was to much, so i came to the website and saw the screen repair kit.
my question was i coudn't see any thing on the screen expect for white light coming inside of the iphone if i buy the repair kit will that fix my problem.
Thank You
Score -1
Add a comment
Chosen Solution
ayush, you did not tell us if you see the white light on your old screen or a new one. If a car ran over your phone it stands to reason that at minimum you will need a new front display assembly. If your lcd only shows white light, that means the backlight is working, but not the video circuitry. A new LCD "might" fix this but you have to evaluate everything else as well. I would suggest you disassemble your phone by using these guides and see if you find any other damage. Pay particular attention to the logic board. Hope this helps, good luck.
Score 1
Add a comment
I think the best solution for you is bring your phone to that repair shop that has the experience to fix it. Tough the repair is not that hard to do it yourself, you might have a better chance with the shop. The reason wy you're screen is black, because the LCD is damaged, normally when replacing the LCD and touchscreen, youre phone should work just normal again.
1 Comment:
i see the white light on my phone when i turn it on;
by
Add a comment
Add your answer
ayush will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 123
